codigo arduino
hola, soi nuevo por aqui.haber si me podeis ayudar con este codigo. soi novato.
#include <OneWire.h>
#include <DallasTemperature.h>
#include <LiquidCrystal.h>
#define ONE_WIRE_BUS 10
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int temp=27;
int rele1 =6;
int rele2 =7;
int rele3 =8;
int rele4 =9;
int rele5 =14;
void setup() {
pinMode(rele1,OUTPUT);
pinMode(rele2,OUTPUT);
pinMode(rele3,OUTPUT);
pinMode(rele4,OUTPUT);
pinMode(rele5,OUTPUT);
digitalWrite(rele1,HIGH);
digitalWrite(rele2,HIGH);
digitalWrite(rele3,HIGH);
digitalWrite(rele4,HIGH);
lcd.begin(20, 4);
pinMode(13,OUTPUT);
digitalWrite(13, HIGH);
sensors.begin();
lcd.setCursor(4, 1);
lcd.print("HOLA ");
lcd.setCursor(4, 2);
lcd.print("CARGANDO ");
lcd.setCursor(4, 3);
lcd.print(" SISTEMA ");
delay(5000);
digitalWrite(rele5,LOW);
void loop() {
sensors.requestTemperatures();
lcd.setCursor(0, 0);
lcd.print("Deposito 1: ");
lcd.print(sensors.getTempCByIndex(0));
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print("Deposito 2: ");
lcd.print(sensors.getTempCByIndex(1));
lcd.print("C");
lcd.setCursor(0, 2);
lcd.print("Deposito 3: ");
lcd.print(sensors.getTempCByIndex(2));
lcd.print("C");
lcd.setCursor(0, 3);
lcd.print("Deposito 4: ");
lcd.print(sensors.getTempCByIndex(3));
lcd.print("C");
if (sensors.getTempCByIndex(0)>temp)
digitalWrite(rele1,LOW);
else
if (sensors.getTempCByIndex(1)>temp)
digitalWrite(rele2,LOW);
else
if (sensors.getTempCByIndex(2)>temp)
digitalWrite(rele3,LOW);
else
if (sensors.getTempCByIndex(3)>temp)
digitalWrite(rele4,LOW);
else
if (rele1 && rele2 == HIGH);
if (rele1 && rele3 == HIGH);
if (rele1 && rele4 == HIGH);
if (rele2 && rele3 == HIGH);
if (rele3 && rele4 == HIGH);
if (rele1 && rele2 && rele3 == LOW);
digitalWrite(rele5,HIGH);
if (rele1 && rele2 && rele4 == LOW);
if (rele4 && rele3 && rele2 == LOW);
if (rele4 && rele3 && rele1 == LOW);
if (rele4 && rele2 && rele1 == LOW);
en la pantalla funciona bien y los reles tan bien pero el rele5 no.
Gracias de antemano.
Posiblemente tengas el error en esa logica ya que se pueden dar varios casos afectado a los siguientes, y tienes condiciones repetidas, posiblemente te este pasando el rele de LOW a HIGH en cuestion de milisegundos y el rele al ser tan lento ni cierra el circuitopor eso no "funciona", te falta algun que otro delay y revisar esa logica utilizando un case o un elseif.
Mi recomendacion que pongas delay y escribas en la pantalla la condicion asi sabras por que condicion esta pasando siempre, y poder depurarlo.
PD: si explicas un poco el proyecto o lo que quieres consegir a lo mejor te podemos orientar con el codigo.
Hola, muchas gracias por comtestar. el proyecto es para enfriar unas depositos, con un sensor de temperatura y unas valvulas que hacen que pase agua fria. el quinto rele es para una quinta valvula que hace baipass. cuando uno o varios reles esten activados que el quinto se apage y cuando esten apagados que el quinto encienda. Eso es la idea.(tengo que mirar el caudal de la bonba, que a lo mejor hay activar o dessactivar con un rele o dos). gracias otra vez por tu tiempo. un saludo.
hola, alguien me puede ayudar, gracias de todos modos, sigo con las pruebas
buenaas jhony, lo que intentas hacer es a nivel bit, prueba con un sólo &
Por otro lado, elimina parte de los casos ya que tienes casos repetidos en distinto orden
Hola gracias por responder. Pero ya dí con la solución, lo estoi probando. Ya colgare el código aquí.
hola. Aqui os dejo el codigo por si alguno le interesa.
Archivos adjuntos
.rar   sensor_.rar (Tamaño: 1.14 KB / Descargas: 46)
  conversión código arduino ethernet 5100 a wemos d1 mini nbaglietto 0 499 24-11-2017, 02:05 AM
Último mensaje: nbaglietto
  Problemas subiendo codigo al ESP8266 igargi 6 5,698 18-09-2017, 04:04 AM
Último mensaje: CarlosTM
  Ayuda con codigo boton de pause motor PaP fredyr 2 617 22-08-2017, 08:48 PM
Último mensaje: fredyr
  Codigo morse con arduino antonio_gt_9.2 0 1,335 08-12-2016, 08:06 PM
Último mensaje: antonio_gt_9.2
  problema con shield para arduino para cargar el codigo homer32 6 1,736 17-10-2016, 07:49 AM
Último mensaje: homer32
