  • 1 voto(s) - 1 Media
Printerboard arduino + ramps+ pololu integrado
seguro que alguno ya la conoce pero, como he mirado en el buscador y no aparece nada lo pongo, es una placa con todo integrado arduino ramps y pololu todo en uno, tiene muy buena pinta, haun que no se cuando se fria un pololu que tal sera para des soldarlo y poner otro, otra es que solo tiene para un extrusor, lastima
sale a 60 dolares, me imagino que no tardara mucho en bajar el precio
Description:
Printrboard is a derivative of Teensylu, an AT90USB1286 development board originally based on Sanguinololu. The Printrboard electronic set eliminate the production and functionality shortcomings of older RepRap electronics sets. Printrboard improves upon the previous production-grade electronics set (Gen6) by adding heatbed and SD card support, reverting to 1/16 microstepping Allegro stepper drivers, and improving connectivity reliability and reducing cost by elimination of the FTDI UART chip. Printrboard also has expansion headers supporting I2C, SPI, UART, and ADC pins. All extra I/O ports of the AT90USB have been broken out to headers for prototyping and expansion. The Atmel AT90USB1286 MCU has on-chip USB, removing the need for the FTDI UART (USB-to-serial) IC. On-chip USB means dramatically faster firmware upload times and communication. The AT90USB connects at any baud rate regardless of firmware configuration, and operates virtually free of serial communication errors/pauses.
Features:
1. Atmel AT90USB1286 Microcontroller (or AT90USB1287 drop-in compatible for 20mhz support)
-- Native USB interface. No FTDI serial-to-USB chip!
-- 128kb Flash
2. Four integrated Allegro A4982 Stepper Drivers (no Pololus needed)
3. Onboard SD card slot
4. Edge connectors enabling right-angle connections
https://www.youtube.com/watch?v=91Pvyhqhlho
fuente http://www.geeetech.com/new-version-repr...p-653.html
pero sigo con la idea del quien le meta el rele incorporado o con tomas directas lo peta :yeah:
El problema es el que comentas. Si se te quema algo, puede ser un buen marrón.
Yo no me arriesgaría a tener todo integrado, por experiencia se que cuantas mas cosas estén en una sola placa más facil es que se estropeen y más dificil de reparar porque si se te quema un a4988 no son fáciles ni baratos de conseguir los integrados smd.
  Y ahora que la Ramps se queda corta que compro? kaituss 14 973 08-02-2019, 01:44 PM
Último mensaje: NBla
  APORTE [TUTORIAL] Conectar Ramps/OVM20 con Raspberry Pi Zero cansi22 11 2,039 29-11-2018, 03:28 PM
Último mensaje: mundo2017
  Consulta TMC2208 y Ramps elaspi 9 496 22-11-2018, 01:58 PM
Último mensaje: Shellmer
  CONSULTA ventajas ramps 1.4 1.6 davlinares 1 270 08-11-2018, 09:18 PM
  Conectar TFT tactil a ramps Jaimelito 22 6,400 26-08-2018, 03:52 PM
Último mensaje: Leo
