CONSULTA Pantalla MKS TFT 32 V2.0
Tengo un problema con esta pantalla el cual es que la misma prende pero cuando presiono cualquier boton la maquina no hace nada, revise los baudios y estan bien configurados, como dato es que esta conectada a una ramps 1.4, les dejo la config que tiene la pantalla.
#########Printer type setting############################
#mainboard firmware setting(marlin:1; repetier:2; smoothie:3)
>cfg_firmware_type:1
#machine setting (Normal:1; Delta:2)
>cfg_machine_type:1
#baud rate setting(1:9600;2:57600;3:115200;4:250000)
>cfg_baud_rate:4
#language (Simplified Chinese:1; traditional Chinese:2; English:3)
>cfg_language_type:3
#extruder number(one:1; dual:2)
>cfg_sprayer_counter:1
#whether has heated bed(YES:1; NO: 0)
>cfg_custom_bed_flag:1
########function settings#################################
#pause position (-1 is invalid; Z-axis is relative position)
>cfg_XPOS:-1
>cfg_YPOS:-1
>cfg_ZADD:10
#whether set machine auto-off after print finishes(auto-off:1; NO:0)
>cfg_print_finish_close_Machine:0
#the max target Temp of sprayer and heated bed
>cfg_max_sprayer_temperature:270
>cfg_max_hotbed_temperature:150
#the level signal of outage detection module PB1(low level:0; high level:1)
>cfg_PB0_PB1_Level:1
#the speed of filament replacing(mm/min)
>cfg_filament_change_speed:1200
#the length of filament replacing(mm)
>cfg_filament_change_step:5
#the min temperature of filament replacing
>cfg_filament_limit_temperature:175
#The command of auto leveling (G29 is available for Marlin.While G32 is for  Repetier and Smoothieware)
>cfg_auto_leveling_cmd:G28;G29;
#The point number of manual leveling:(3,4,5 point available)
>cfg_point_number:4
#the coordinates of 5 point on manual leveling
>cfg_point1:50,50
>cfg_point2:180,50
>cfg_point3:180,180
>cfg_point4:50,180
>cfg_point5:150,150
#the moving speed of leveling(mm/min)
>cfg_leveling_z_speed:1500
>cfg_leveling_xy_speed:3000
#Breakpoints continued playing Z-axis error setting
>cfg_breakpoint_z_error:0.2
#wifi mode(AP:1; STA:0)
>cfg_wifi_mode:1
#wifi name and password
>cfg_wifi_ap_name:MKS_wifi
>cfg_wifi_key_code:makerbase
#Dynamic access IP
>cfg_ip_dhcp_flag:1
#IP/mask/gateway
>cfg_ip_address:192.168.3.100
>cfg_ip_mask:255.255.255.0
>cfg_ip_gate:192.168.3.1
##############Function customization####################
#user-defined function1 and 2.(whether display this button .  disable: 0; enable: 1)
>cfg_function_btn1_display:1
>cfg_function_btn2_display:0
#command of user-defined function
>function_btn1_cmd:M84;
>function_btn2_cmd:M81;
#set number of  "More" button
>moreitem_pic_cnt:0
#edit command for 1~7 "More" button,each command must be separated by semicolon ";"
>moreitem_button1_cmd:G28 X0;
>moreitem_button2_cmd:G28 X0;
>moreitem_button3_cmd:G28 Y0;
>moreitem_button4_cmd:G28 Y0;
>moreitem_button5_cmd:G28 Z0;
>moreitem_button6_cmd:G28 Z0;
>moreitem_button7_cmd:G28;
#how many "More" button show on screen interface
>morefunc_cnt:0
#command setting on button1~6
>morefunc1_cmd:G28;
>morefunc2_cmd:G28;
>morefunc3_cmd:G28;
>morefunc4_cmd:G28;
>morefunc5_cmd:G28;
>morefunc6_cmd:G28;
##Display customization(button and logo customized see User's Manual)####
#the color of screen background
>cfg_background_color:0x000000
#the color of title text
>cfg_title_color:0xFFFFFF
#the color of temperature,fan,(etc) background
>cfg_state_background_color:0x000000
#the color of temprature,fan,(etc) text
>cfg_state_text_color:0xFFFFFF
#the color of file button
>cfg_filename_background_color:0x000000
#the color of file text
>cfg_filename_color:0xFFFFFF
#the color of background in printing
>cfg_printingstat_word_background_color:0x000000
#the color of text in printing status
>cfg_printingstat_word_color:0xFFFFFF
#3D effects setting (disable: 0; enable: 1)
>cfg_BUTTON_3D_effects:0
Yo no le veo nada raro a la configuración, pero seria bueno saber la placa que llevas
Me pasa lo mismo que a ti. Yo tengo la 3.0 y solo tengo el cable plano conectado. No se si necesitaré alimentarlo aparte. Lo conseguiste solucionar?
Con la otra pantalla que tengo se mueve sin problemas, pero con esta, no se mueve.
Saludos y gracias!
lo unico que ai que tocar en el firmware de la ramps y el de la pantalla, es que las 2 vayan ala misma velocidad (baudios), con eso ya funciona perfectamente.
yo mismo la he probado en ramps, trigorilla y mks gen L y sin problemas
el formato de la tarjeta on que metes la actualización de la tft mks tiene que ser exfast32 si le pones otro formato la mks tft no reconoce la tarjeta por lo que no te met el fichero config que te hace funcione bien
Pero el config sólo hay que meterlo una vez, después de haber actualizado el firmware de la pantalla, no necesitas tenerlo, es mas, la pantalla renombrará el config para que no se actualice de nuevo
(16-06-2018, 10:26 AM)neoxM3 escribió: lo unico que ai que tocar en el firmware de la ramps y el de la pantalla, es que las 2 vayan ala misma velocidad (baudios), con eso ya funciona perfectamente.
Buenas noches, me acabo de iniciar en el mundillo de la impresión 3D y estoy configurando mi impresora. Placa MKS GEN L y MKS TFT 32. He seguido el tutorial de Youtube de JC3Design pero no termino de entender si hay que descomentar algún controlador en el firmware Marlin v1.1.9, o entre ambas se entienden sin más. ¿Podríais ayudarme?
Gracias por adelantado y un saludo.
yo soy JC3Design xD
solo tienes que dejar descomentada la de serie, reprap discount,, luego teniendo configurados los mismos baudios en placa y pantalla, se entienden entre ellas
