02-10-2014, 09:00 AM
Por solo 218€ podemos comprar una montada.
No se estoy pensando en comprar una a mi hijo. que opináis.
http://www.hispazone.com/Noticia/6497/Mi...rcado.html
Estas son las caracteristicas no se parece que está bien.
Technical Specifications
Printer Dimensions: It's a cube, 7.3 in (185 mm) per side.
It is lightweight, roughly 2.2 lb (1 kg).
It can also be used with any Windows, Mac, or Linux based system.
USB-Compatible connection.
Supports many different materials: ABS, PLA, Nylon, and more.
Filament: standard 1.75mm. Nearly 1/2 lb (225 g) rolls.
Standard filament rolls also supported.
Removable Print Bed.
50-350 micron layer resolution.
15 micron X and Y positioning accuracy.
Dimensions: Print height: 116mm (4.6"). Base Print Area: 109mm x 113mm. Print Area Above 74mm: 91mm x 84mm.
M3D software for an effortless, plug-and-play experience.
Supports and uses open source software (for advanced users).
