[VENDO] Unidad demo de FORMBOT T-Rex2+ Dual Extruder 400x400x500 + LASER + HTExtruder
VENDO Unidad demo de la Formbot Trex2+
Solo se ha impreso 3 veces con ella
Viene con extrusor dual, unidad Laser y extrusor adicional para filamentos que requieran 300ºC
Viene con cama caliente "Keenovo" + kit SSR para instalar y controlarla por Gcode
Viene con Buildtak Removable System incluido y ya instalado!
PVPR: 2495Eur (sumando todos los extras que lleva)
La dejo por 1650€ur envio incluido a la peninsula.
+ info del fabricante:
New affordable, massive scale 3D printer. Amazing 40x40x50cm build volume.
DUAL EXTRUSION System. High Temp Extruder. LASER Engraver. GENUINE BLTouch included. LINEAR Guide.
[size=undefined][size=undefined]
T-Rex 2+ 500, Large Format Multifunctional 3D Printer
Auto bed leveling system with probe that meassures 225 points.
Delivered with:
[/size][/size]
  • High Temp Extruder
  • Dual Zone Keenovo heated bed
  • Laser engraver
[size=undefined][size=undefined][size=undefined]
Simply a great printer for more demanding user with features like:[/size]
[/size][/size]
  • Large build size 400x400x500mm
  • Independent dual extruder (IDEX): possibility of printing 2 materials at a time or 2 identical objects simultaneously.
  • Extruder wiping system: to avoid messy layers at the beginning of a 3D print, the extruders are automatically wiped.
  • Auto-leveling: no need for time-consuming manual bed leveling.
  • High-temperature extruder (included): for printing PEEK, nylon and other filaments that require high temperatures to be 3D printed.
  • Dual zone heated print bed (included): the heating is divided into 2 areas, to avoid useless heating of unused areas (a smaller portion of 200 x 200 can be heated for small objects, while the whole print bed can be heated for larger prints).
  • Laser engraver (included): capable of engraving wood, fabrics and other materials.
  • Built with high quality components
  • Stable and sturdy frame with thick linear rail and bearings
  • Industrial ball screws to ensure amazing z accuracy
T-Rex 2+ comes assembled nearly, only takes 10-15 minutes to complete assembly, very easy to operate.
Note: for better performance, we have upgraded Raptor with TBI ball screw, which will eliminate the clearance, better for auto bed leveling. meanwhile, it’ll bring more silent working environment and longer service lifespan.
 [/size]
undefined
+ info y fotos:
https://www.en3dstudios.com/product/formbot-t-rex-2-500-400x400x500mm-build-volume-dual-extruder-and-laser-engraver-3d-printer/[/size][/size]
Puede ser negociable ???
La verdad es que esta por debajo del precio de coste de todo lo que lleva....
SIGUE DISPONIBLE.
se puede recoger en mano? de donde eres?
  [VENDO] Unidad demo a ESTRENAR de FORMBOT RAPTOR 400x400x500 bolsoncerrado 0 303 18-07-2018, 06:05 PM
Último mensaje: bolsoncerrado
  Vendo grabadora / cortadora laser 2,5w neoxM3 7 1,105 29-07-2017, 12:07 AM
  [Vendo] LaserCNC con diodo laser de 3W grafisoft 13 2,458 22-09-2016, 11:47 AM
  Vendo estructura para maquina laser hasta 3W completa al 80% estilo MiXY neoxM3 3 1,478 03-09-2016, 05:35 PM
  Vendo o cambio Grabadora Laser NEJE DK 8 Pro 5 500 mW Jomagom 1 1,000 18-05-2016, 02:38 PM
Último mensaje: Raul001
