13-11-2013, 12:17 PM
Acaba de salir la nueva version de la multiwii, la 2.3 (9 de noviembre)
Por si alguien esta pendiente de actualizar. Se puede descargar aqui: http://code.google.com/p/multiwii/downlo...p&can=2&q=
Y la lista de cambio es esta:
***Control mode***
- main PITCH/ROLL/YAW PID modification (r1474)
- the sticks scaling is no more affected by PID coefficients
- yaw rate (to the right of the PIDs in GUI) now works as stick scaling
- default yaw rate is increased (with yaw rate at 0)
- yaw PID principle is now different from PITCH&ROLL PID:
- yaw ITerm windup is very high, allowing an 'elastic' direction return after a manual perturbation
- yaw ITerm is also constrained with a windup independent limit
- yaw PTerm is constrained in order to counter the yaw jump effect.
use yaw DTerm to increase this constrain (r1573)
- yaw ITerm is canceled if the yaw stick is not centered
- Throttle angle correction (r1374)
- Advanced Headfree mode added (see config.h for instructions) (r1374)
- DYNBALANCE option, individual motor can be controled via GUI, to test individual vibration
- better gyro & acc calibration accuracy (r1546)
- cannot arm is baro mode is on (r1550)
! baro mode should be activated only when the multi is nearly Z stable !
- only one baro mode : vario around a throttle deadband (r1554)
- magHold is reset when arm is switched on (r1553)
- ONLYARMWHENFLAT option (r1587)
***receiver & UART***
- RCSERIAL is now deeply integrated. If a MSP_SET_RAW_RC comes, it will just override legacy RX data. (r1420)
as a consequence, RCSERIAL is no more an option
- no RC averaging for Spektrum & SBUS (r1545)
- SBUS center define (r1568)
- FAILSAFE_DETECT_TRESHOLD configurable
***GPS***
- Enables sonar altitude from i2c-gps-nav board (1424)
- navigation code will follow after 2.3
***GUI***
- Gui with Servosettings. (r1441 & r1450)
All models with servo included.
- GUI globalsettings (for some settings previously only in config.h)
- do not display /dev/cu.* devices but only corresponding /dev/tty.* (r1442)
- GUI baudrate as configurable setting
***LCD***
- lcd.telemtry: show max ground speed from gps data (r1398)
- lcd.telemetry: allow separate suppression of aux2 configuration (r1456)
- new display support 1.3" i2c OLED from digole.com (r1413)
- config.menu: when abort, revert all values back to last saved state
- visual feedback from servos during midpoint trim via LCD
***IMU and baro***
- correct GYRO_SCALE for all gyro (r1428)
- no more small angles while shaking the board (r1579)
- baro Alt based on ground temp compensation (r1570)
- not I reset for FIWEDWING (r1590)
- add 6DOF LSM330 sensor (r1571)
- add ACC BMA280 sensor (r1600)
*** SERVO management ***
warning:
The pins for coptertypes with servos have been changed.
Attaching a servo to a motor pin can quickly destroy your servo.
All connection diagrams out there from v2.2 or older are no longer valid for v2.3 with servos using hardware PWM.
http://www.multiwii.com/wiki/index.php? ... figuration
- add 8 hardware PWM's for servos on MEGA boards. Servo outputs are 44,45,46,11,12,6,7,8 (r1384)
- Allow any servo refresh rate from 20 to 400Hz on Mega hardware PWM servos. (r1386)
- Tri servo moved to SERVO4 (pin11) on mega boards with HW PWM's. (r1392)
- a32u4 (nanoWii, MicroWii etc) HW PWM for 4 servos; warning different pins!!
(with lots of info and help from ronco)
(r1464 & r1470)
- add a generic way to configure servo settings : conf struct + MSP read/set messages (r1383)
- Added general servo handler (r1421 & r1429)
- allow preset of some servo stuff from config.h (r1432)
- Gui with Servosettings. (r1441)
- add gimbal servo stretcher usable with HW PWM's. (r1384)
We can get 180 degrees servo move without servo modification.
- note about gimbal: settings for neutral&endpoints are no more in config.h, but only in GUI
- do not update servos during unarmed calibration of sensors which are sensitive to vibration (r1408)
***internal improvements***
- migration to a cpp/h code structure (r1515 & r1516)
- huge flash size optimization (around 1k)
thanks to fine struct definitions + serialization over MSP (r1369)
- make powermeter computation time based (again) to reduce config hassle and increase accuracy (r1375)
- read at most one analog channel per MWii main loop cycle (r1375)
- smoothing of RX_RSSI (r1379)
- make faster analog reads an option with default off to increase accuracy (r1375)
- detangle vbat & buzzer dependancy (r1375)
- optimization : small approximation bit shift used instead of * or / number
for TPA, rates, dynP, dynD and expo curb (r1376)
- Added checking for flash content change, and reload config parameters in this case. (r1389)
- split Serial into Serial(core UART management) & Protocol (r1548)
- loop is globally faster
***add-ons***
- option to suppress defaults in mwc sketch and load via gui from file instead (r1365)
- add OVERRIDE_PSENSORPIN option (r1375)
- manual for using Multiwii in Eclipse environment
- add amperage to MSP_ANALOG (r1542)
- MY_PRIVATE_DEFAULTS (r1559)
- no more than one MSP per port and per cycle
should smooth the delay while requesting MSP, especially for USB port on micro
***Control mode***
***GPS***
***GUI***
***LCD***
***IMU and baro***
warning:
(r1464 & r1470)
***add-ons***
