  • 13 voto(s) - 4.62 Media
Un volcado de la EEpron de la anet a8:
Anet A8 Standard EEPROM Settings
Free RAM:12337
FIRMWARE_NAME:ANET_A8_20160525  http://www.anet3d.com/ VERSION:ANET V1.0 MACHINE_TYPE:ANET_A8 EXTRUDER_COUNT:1
Configuration Settings
EPR:2   75   115200     Baudrate
EPR:3 129   500.928     Filament printed [m]
EPR:2 125   434227     Printer active [s]
EPR:2   79   0     Max. inactive time [ms,0=off]
EPR:2   83   360000     Stop stepper after inactivity [ms,0=off]
EPR:3     3     100.0000     X-axis steps per mm
EPR:3     7     100.0000     Y-axis steps per mm
EPR:3   11     400.0000     Z-axis steps per mm
EPR:3   15     400.000     X-axis max. feedrate [mm/s]
EPR:3   19     400.000     Y-axis max. feedrate [mm/s]
EPR:3   23     8.000     Z-axis max. feedrate [mm/s]
EPR:3   27     100.000     X-axis homing feedrate [mm/s]
EPR:3   31     100.000     Y-axis homing feedrate [mm/s]
EPR:3   35     4.000     Z-axis homing feedrate [mm/s]
EPR:3   39     20.000     Max. jerk [mm/s]
EPR:3   47     0.300     Max. Z-jerk [mm/s]
EPR:3 133     0.000     X home pos [mm]
EPR:3 137     0.000     Y home pos [mm]
EPR:3 141     0.000     Z home pos [mm]
EPR:3 145     250.000     X max length [mm]
EPR:3 149     228.000     Y max length [mm]
EPR:3 153     240.000     Z max length [mm]
EPR:3   51     400.000     X-axis acceleration [mm/s^2]
EPR:3   55     400.000     Y-axis acceleration [mm/s^2]
EPR:3   59     400.000     Z-axis acceleration [mm/s^2]
EPR:3   63     400.000     X-axis travel acceleration [mm/s^2]
EPR:3   67     400.000     Y-axis travel acceleration [mm/s^2]
EPR:3   71     400.000     Z-axis travel acceleration [mm/s^2]
EPR:0 880     0     Autolevel active (1/0)
EPR:0 106    0     Bed Heat Manager [0-3]
EPR:0 107     255     Bed PID drive max
EPR:0 124     80     Bed PID drive min
EPR:3 108     196.000     Bed PID P-gain
EPR:3 112     33.000     Bed PID I-gain
EPR:3 116     290.000     Bed PID D-gain
EPR:0 120     255     Bed PID max value [0-255]
EPR:3 200     95.000     Extr.1 steps per mm
EPR:3 204     50.000     Extr.1 max. feedrate [mm/s]
EPR:3 208     20.000     Extr.1 start feedrate [mm/s]
EPR:3 212     1000.000     Extr.1 acceleration [mm/s^2]
EPR:0 216     3     Extr.1 heat manager [0-3]
EPR:0 217     230     Extr.1 PID drive max
EPR:0 245     50     Extr.1 PID drive min
EPR:3 218     7.0000     Extr.1 PID P-gain/dead-time
EPR:3 222     2.0000     Extr.1 PID I-gain
EPR:3 226     40.0000     Extr.1 PID D-gain
EPR:0 230     255     Extr.1 PID max value [0-255]
EPR:2 231     -3000     Extr.1 X-offset [steps]
EPR:2 235     -800     Extr.1 Y-offset [steps]
EPR:1 239     1     Extr.1 temp. stabilize time [s]
EPR:1 250     150    Extr.1 temp. for retraction when heating [C]
EPR:1 252     0     Extr.1 distance to retract when heating [mm]
EPR:0 254     255     Extr.1 extruder cooler speed [0-255]
Fuente el facebook oficial de Anet.
Hola compañeros,no se si conoceis esta tienda,pero tiene muy buenos precios,si alguien la conoce,me podria decir.
http://www.3dpenedes.com/
Para usar Octoprint es necesario ponerle Skynet3d? He instalado OctoPi en mi raspberry 2B y no me detecta la impresora. Me imagino que es porque sigo con el firmware de fábrica... ando muy desencaminado?
De repente el eje Z no me funciona correctamente. Solo sube, pero no baja..
A alguien le ha pasado o sabe como solucionarlo?
(27-02-2017, 10:16 PM)joseslo escribió: Para usar Octoprint es necesario ponerle Skynet3d? He instalado OctoPi en mi raspberry 2B y no me detecta la impresora. Me imagino que es porque sigo con el firmware de fábrica... ando muy desencaminado?
Me respondo yo mismo. Sí que funciona, solo que no autodetecta la conexión... Lo único que no va es listar los archivos de la SD.
Cuando tu impresora llega a la adolescencia....resim
wow... por estas cosas nunca se debe dejar sola de todo una impresora 3d sin control :-P
De que medida serian los casquillos para cambiarselos al carro del extrusor?serian de la misma medida que los Rodamientos lineales LM8UU?
Efectivamente. Pero es que la sd pierde un poco de sentido tambien. Yo la he quitado.
(27-02-2017, 10:52 PM)israel_sanchez19 escribió: Cuando tu impresora llega a la adolescencia....resim
Octoprint!!!!
Octoprint!!!!
La sd china que es una mierda,la cambié y ahora 0 problemas
(27-02-2017, 11:16 PM)israel_sanchez19 escribió: De que medida serian los casquillos para cambiarselos al carro del extrusor?serian de la misma medida que los Rodamientos lineales LM8UU?
no, los casquillos son 30x11x8... diseñe un carro ya que cambiaba , para añadir el titan
pero si te haces con 3 casquillos 22x11x8, e imprimes 3 piezas de estas que saque para la cama:
http://www.thingiverse.com/thing:2117514
puedes convertir a casquillos el eje x sin problema con el extrusor de serie
Creo que las mejoras las Imprimiré en rojo
(27-02-2017, 10:29 PM)skt_jk escribió: Hola,
He probado a cambiar los motores de conector y en otro conector si que van hacia ambos lados. Entonces he probado otro motor en el conector z y solo funciona hacia un lado. conclusión: es problema de los conectores Z de la placa, pero.. hay alguna forma de corregir esto?
Yo estoy igual, el eje Z solo sube cuando hace el home, los motores están bien y las conexiones tambien,
hay veces que de repente lo hace bien y la impresion la hace perfectamente y a la siguiente impresion vuelve a fallar.
He comprobado los finales de carrera, he comprobado los termistores, la fuente de alimentación, los motores,
he reinstalado el firm varias veces tambien he probado con el firm de SKYNET y no se arregla, ya no se que mas comprobar.
Hola majos, después de fundir un rollo de PLA entero viendo sus ventajas y desventajas , he empezado con ABS y después de comprobar sus insufribles esperas para que la cama coja temperatura me he tenido que conformar con imprimir a 95º y aun así esperando a que los últimos grados llegaran para el comienzo una eternidad, y comprobar que a mitad de impresión bajaba a 92 o 91 de vez en cuando, para solucionarlo estoy probando en este momento con papel de aluminio doble entre la hache (sujeto a la misma en los bordes) y entre la cama , la subida de temperatura a sido rapidísima en comparación, y mientras imprime no baja de 95º, parece una buena solución de momento solo queda sujetar más firmemente el aluminio a la hache para evitar que se suelte con los movimientos y ya os contare , de momento me parece una solución muy buena y barata, seguramente puedo subirla más de temperatura, pero por miedo a vuestros comentarios de conexiones quemadas etc… no me atrevo. Un saludo y perdón por el tocho pero creo que merece la pena para muchos.
(28-02-2017, 06:13 AM)trolex escribió: Yo estoy igual, el eje Z solo sube cuando hace el home, los motores están bien y las conexiones tambien,
A mi me da de que tenéis intercambiados los Microswhitch, aveces vienen mal etiquetados.
Los Microswhitch solo detienen los motores al ir al home, que es lo que os sucede.
Si alguien quiere cambiar los rodamientos lineales de bolas por casquillos de bronce sin complicarse demasiado, solo tiene que sustituir los rodamientos que están dentro de los scs8uu por estos que son de la misma medida:
https://es.aliexpress.com/item/Free-ship...86633.html
(28-02-2017, 09:10 AM)cachispas escribió: Hola majos, después de fundir un rollo de PLA entero viendo sus ventajas y desventajas , he empezado con ABS y después de comprobar sus insufribles esperas para que la cama coja temperatura me he tenido que conformar con imprimir a 95º y aun así esperando a que los últimos grados llegaran para el comienzo una eternidad, y comprobar que a mitad de impresión bajaba a 92 o 91 de vez en cuando, para solucionarlo estoy probando en este momento con papel de aluminio doble entre la hache (sujeto a la misma en los bordes) y entre la cama , la subida de temperatura a sido rapidísima en comparación, y mientras imprime no baja de 95º, parece una buena solución de momento solo queda sujetar más firmemente el aluminio a la hache para evitar que se suelte con los movimientos y ya os contare , de momento me parece una solución muy buena y barata, seguramente puedo subirla más de temperatura, pero por miedo a vuestros comentarios de conexiones quemadas etc… no me atrevo. Un saludo y perdón por el tocho pero creo que merece la pena para muchos.
Ojo con el aluminio debajo de la cama, no te vaya a hacer contacto.
Yo he hecho un sandwitch con aluminio y material aislante (que puede ser corcho). Pero ya te digo que pasar de 100 es practicamente imposible. NI en esta, ni en otra prusa que tube y que le puse relé. A mi me tarda casi media hora en llegar a los 100.
De todas formas, a 95 se puede imprimir ABS. Cantidades industriales de buena laca. Y la primera capa que esté mas bien apretada contra el cristal, que no suelta
Tambien he descubierto que imprimiendo con las capas a 0,1. Reducía bastante los problemas de warping.
Ah... y tambien muy importante. Cabinar la impresora para evitar diferencias termicas bruscas. Yo he usado de momento una caja y se nota.
Si ha estado funcionando, y/o si a veces funciona y a veces no. Yo miraría que no haya una soldadura fría en el pin del driver que hace que el motor gire en un sentido o en el otro.
Enviado desde mi D6603 mediante Tapatalk
Los Microswhitch estan bien, las soldaduras repasadas, todo esta aparentemente bien, pero sigue fallando.
  pantalla anet 6 para la Anet 8 Nestor 12 4,452 12-04-2018, 08:35 PM
Último mensaje: Josnaro
  Post Importante de Sobre Filamentos Logan83 1 1,223 03-09-2017, 07:30 AM
Último mensaje: ICEM4N
  ¡¡Problema definitivo !! Westy 10 2,001 26-04-2017, 01:24 PM
Último mensaje: Westy
  Primer post en el foro. Simemart 6 1,518 02-04-2017, 11:52 PM
  Anet A8 - Dudas y soluciones - Recopilatorio de temas stigmata1987 980 225,372 14-01-2017, 01:34 PM
