ramps1.6 + tmc2208
estimados espero me puedan ayudar, les paso a contar...
es mi primera impresora pues tiene
ramps 1.6 plus
tmc2208
marlin2.0 bug fix
core xy
al momento de conectar el repetir host al arduino este no reconoce los driver de moto segun el registro
los tmc estan soldados en su pin PDN y la ramps esta sin jumper debajo de los tmc. marlin caga sin problema y lee sin problema los TO.
17:20:30.523 : Printer reset detected - initializing
17:20:30.523 : echoConfundidotart
17:20:30.523 : Marlin bugfix-2.0.x
17:20:30.527 : echo: Last Updated: 2020-07-29 | Author: (none, default config)
17:20:30.528 : echo:Compiled: Nov  1 2020
17:20:30.531 : echo: Free Memory: 5152  PlannerBufferBytes: 1136
17:20:31.550 : echo:V81 stored settings retrieved (657 bytes; crc 33765)
17:20:31.841 : Testing X connection... Error: All LOW
17:20:31.862 : Testing Y connection... Error: All LOW   (no reconoce )
17:20:31.882 : Testing Z connection... Error: All LOW
17:20:31.903 : Testing E connection... Error: All LOW
17:20:31.917 : FIRMWARE_NAME:Marlin bugfix-2.0.x (Nov  1 2020 22:36:08) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
17:20:31.917 : Cap:SERIAL_XON_XOFF:0
17:20:31.918 : Cap:BINARY_FILE_TRANSFER:0
17:20:31.918 : Cap:EEPROM:1
17:20:31.919 : Cap:VOLUMETRIC:1
17:20:31.920 : Cap:AUTOREPORT_TEMP:1
17:20:31.920 : CapLenguaROGRESS:0
17:20:31.920 : CapLenguaRINT_JOB:1
17:20:31.920 : Cap:AUTOLEVEL:0
17:20:31.920 : Cap:RUNOUT:0
17:20:31.921 : Cap:Z_PROBE:0
17:20:31.923 : Cap:LEVELING_DATA:0
17:20:31.924 : Cap:BUILD_PERCENT:0
17:20:31.924 : Cap:SOFTWARE_POWER:0
17:20:31.924 : Cap:TOGGLE_LIGHTS:0
17:20:31.927 : Cap:CASE_LIGHT_BRIGHTNESS:0
17:20:31.928 : Cap:EMERGENCY_PARSER:0
17:20:31.928 : CapLenguaROMPT_SUPPORT:0
17:20:31.928 : Cap:SDCARD:0
17:20:31.928 : Cap:AUTOREPORT_SD_STATUS:0
17:20:31.931 : Cap:LONG_FILENAME:0
17:20:31.932 : Cap:THERMAL_PROTECTION:1
17:20:31.932 : Cap:MOTION_MODES:0
17:20:31.932 : Cap:ARCS:1
17:20:31.935 : Cap:BABYSTEPPING:0
17:20:31.936 : Cap:CHAMBER_TEMPERATURE:0
17:20:31.944 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
17:20:31.944 : echoGran sonrisaEBUG:INFO,ERRORS
17:20:31.944 : echo:Unknown command: "M20"
17:20:31.947 : echo:Unknown command: "M80"
17:20:31.956 : echoGran sonrisaEBUG:INFO,ERRORS
a
