  • 1 voto(s) - 1 Media
Figuras de SpainLabs
DiegoLale escribió:Apunta ahí un llaverito para el caballero :one:
[Imagen: 2j5a.jpg]
Mola
Mi 'moneita':
http://www.thingiverse.com/make:46016
de las mejores que he visto hasta ahora, muy bien calibrada!
Que ganas de tener una cabeza de 0,3 para mejorar la resolucion de las piezas...
Buena moneda, si señor. Que configuración de nozzle, velocidad, etc tenías?
Gracias por vuestros comentarios!
Está impresa con mi Prusa i3 Box Frame (madera), hotend E3d v4.1 (http://www.e3d-online.com/) con nozzle de 0.4 y ABS de 3mm.
Fué de las primeras pruebas que hice y tiene 'excesiva' calidad. Os adjunto el config.ini de slic3r (0.9.9) que utilicé, si soy capaz de adjuntarlo ....
PD.: No consigo adjuntarlo, lo copio aquí:
# generated by Slic3r 0.9.9-dev on Tue Sep  3 13:11:55 2013
avoid_crossing_perimeters = 0
bed_size = 195,170
bed_temperature = 110
bottom_solid_layers = 2
bridge_acceleration = 2000
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 85
brim_width = 5
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nM140 S0\nG28 Y0  ; home X axis\nM84     ; disable motors
external_perimeter_speed = 50%
external_perimeters_first = 1
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 1
fan_below_layer_time = 20
filament_diameter = 2.89
fill_angle = 45
fill_density = 0.75
fill_pattern = rectilinear
first_layer_bed_temperature = 110
first_layer_extrusion_width = 0.60
first_layer_height = 100%
first_layer_speed = 35%
first_layer_temperature = 230
g0 = 0
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.50
infill_first = 0
infill_only_where_needed = 0
infill_speed = 50
layer_gcode =
layer_height = 0.3
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 0
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0.40
perimeter_speed = 40
perimeters = 2
post_process =
print_center = 97,85
raft_layers = 0
randomize_start = 1
resolution = 0
retract_before_travel = 1
retract_layer_change = 1
retract_length = 2
retract_length_toolchange = 3
retract_lift = 0.2
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 50
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 2
slowdown_below_layer_time = 10
small_perimeter_speed = 20
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0.45
solid_infill_speed = 50
start_gcode = G28 ; home all axes
support_material =
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 60
support_material_threshold = 45
temperature = 230
threads = 2
toolchange_gcode =
top_infill_extrusion_width = 0.40
top_solid_infill_speed = 50
top_solid_layers = 2
travel_speed = 200
use_relative_e_distances = 0
vibration_limit = 0
z_offset = 0
La moneda de spainlabs, perfecta para los carros del carrefour :elrisas:
[Imagen: mhskqu.jpg]
[Imagen: 29d8gg0.jpg]
Pillo llavero: http://www.thingiverse.com/make:46997
Fileteado con KISSlicer (deja a veces unos pequeños agujeros sin rellenar), pero por lo demás, genial.
WeSo escribió:Pillo llavero: http://www.thingiverse.com/make:46997
te ha quedado genial. Te entrego tu rango!
Gracias!!
[Imagen: azudygy4.jpg]
Dadme rango que soy el admin tonto y no se ponermelo jajajaja
que buena ocasion para aprender XD
Vamos empezando... por fin!.
Como no podía ser de otra forma, ni cubo de calibración ni nada, directamente una pieza sencillita SpainLabs:
[Imagen: 2445mvt.jpg]
Bueno ya va siendo hora de homologar mi prusa i3, aún no tiene nombre pero hasta que no impruse como debe no la bautizo Gran sonrisa Gran sonrisa Gran sonrisa
[Imagen: a0ezdi.jpg]
Por favor, ¿me podéis dar rango?
[Imagen: cdAMMxFl.jpg]
Me certifico con mi llavero (http://www.thingiverse.com/thing:108315) :elrisas:
ADMIN Cansi: Te reescalo la imagen que era como tres veces el foro :dale2:
Poseedor Prusa i3 edición Conjunta.
Tinkercad: Principiante.
Openscad: Principante.
Thingiverse: http://www.thingiverse.com/vimajo/designs
Una monedica poraki
[Imagen: 153192758f3091252e4b63c5ece27df8o.jpg]
Yo quiero también el rango ... me hace ilusión :yeah: :yeah: después de tanto tiempo esperando y tanto sufrimiento para hacerla funcionar mola el poder tener el rango Guiño Mola
Ah! teníamos curiosidad y esta impreso a un 200% de velocidad y lo ha sacado muy bien para tener en cuenta lo rápido que iba
[Imagen: 47jz.jpg]
llaverito pal carreful!
[Imagen: 2eky.jpg]
Bueno, primera prueba con ABS, aunque se me despegan un poco las capas (¿que puede ser?) ya tengo el llaverillo :-)).
[Imagen: nbhj.jpg]
Saludos!!
  Figuras Halloween isma 2 1,935 29-10-2013, 10:53 PM
Último mensaje: silverhummer
  [Petición] Conversión de figuras linsms 7 3,063 04-10-2013, 06:54 PM
Último mensaje: igargi
  Hilo de figuras imposibles - puzzles OverCraft 4 3,226 04-08-2013, 02:15 PM
Último mensaje: hectorri
  Logo SpainLabs hectorri 3 2,131 14-07-2013, 11:28 PM
